基于单DSP的VoIP模拟电话适配器研究与实现:提出和实现了一种新颖的基于单个通用数字信号处理器(DSP)的VoIP模拟电话适配器方案。DSP的I/O和存储资源非常有限,通常适于运算密集型应用,不适宜控制密集型应用[5]。该系统高效利用单DSP的I/O和片内外存储器资源,采用μC/OS-II嵌入式实时操作系统,支持SIP和TCP-UDP/IP协议,通过LAN或者宽带接入,使普通电话机成为Internet终端,实现IP电话。该系统软硬件结构紧凑高效,运行稳定,成本低,具有广阔的应用前景。
关键词:模拟电话适配器;IP电话;数字信号处理器;μC/OS-II
【Abstract】This paper presents a VoIP ATA solution based on a single digital signal processor (DSP). DSPs are suitable for arithmetic-intensiveapplication and unsuitable for control-intensive application because of the limitation of I/O and memory resources. This solution is based on a 16-bitfixed-point DSP and μC/OS-II embedded real-time operating system. It makes good use of the limited resources, supports SIP and TCP-UDP/IPprotocol. It can connect the analog telephone to Internet and realize the VoIP application. This system has a great future for its high efficiency andlow cost.
【Key words】Analog telephone adapter (ATA); Voice over Internet protocol (VoIP); Digital signal processor (DSP); μC/OS-II
Research and Implementation of VoIPATA Based on Single DSP
