Quectel_EC20_GNSS_AT_Commands_Ma
消耗积分:0 | 格式:pdf | 大小:677KB | 2017-03-13
马丁蜀黍
分享资料个
Quectel_EC20_GNSS_AT_Commands_Manual_V1.1(1)
  EC20是移远通信最近推出的LTE模块,采用LTE 3GPP Rel.9技术,支持最大下行速率100Mbps和最大上行速率50Mbps,同时在封装上兼容移远通信UMTS/HSPA+ UC20模块,实现了从3G网络向4G网络轻松平滑过渡。EC20系列模块包含EC20-A,EC20-C和EC20-E三个版本,使其能够向后兼容现存的EDGE和GSM/GPRS网络,以确保在缺乏3G和4G网络的偏远地区也能正常工作。
1.1. How to Use GNSS EC20 GNSS engine allows calculating location without any assistance from the network. The procedure of turning on GNSS is shown as below: Step 1: Configure corresponding demands by AT+QGPSCFG. Step 2: Active GNSS engine by AT+QGPS. Step 3: After GNSS session is started successfully and GNSS has fixed, positioning information can be obtained by three ways: 1) NMEA sentences output to “usbnmea” port by default, you can read the port to obtain NMEA sentences. 2) You can use AT+QGPSLOC to obtain some positioning information directly, such as latitude, longitude, height, time and positioning type and so on 。 3) After enabling by AT+QGPSCFG, you can acquire the specified NMEA sentence by AT+QGPSGNMEA. If is disabled, this command cannot be used.
评论(2)
发评论
hujhu 2021-03-13
0 回复 举报
谢谢 收起回复
peiyuming 2018-11-16
0 回复 举报
有中文的资料吗,谢谢 收起回复
下载排行榜
全部2条评论
