ADC121S705,pdf datasheet (12-B
消耗积分:2 | 格式:rar | 大小:551 | 2009-10-12
张磊
分享资料个
The ADC121S705 is a 12-bit, 500 kSPS to 1 MSPS sampling
Analog-to-Digital (A/D) converter that features a fully differential,
high impedance analog input and an external reference.
The reference voltage can be varied from 1.0V to VA,
with a corresponding resolution between 244μV and VA divided
by 4096.
The output serial data is binary 2's complement and is compatible
with several standards, such as SPI™, QSPI™, MICROWIRE
™, and many common DSP serial interfaces. The
differential input, low power consumption, and small size
make the ADC121S705 ideal for direct connection to transducers
in battery operated systems or remote data acquisition
applications.
评论(0)
发评论
下载排行榜
