DS92LV1023E,pdf datasheet (30-
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-14
分享资料个
The DS92LV1023E is a 300 to 660 Mb/s serializer for highspeed
unidirectional serial data transmission over FR-4
printed circuit board backplanes and balanced copper
cables. It transforms a 10-bit wide parallel LVCMOS/LVTTL
data bus into a single high speed Bus LVDS serial data
stream with embedded clock. This single serial data stream
simplifies PCB design and reduces PCB cost by narrowing
data paths that in turn reduce PCB size and number of
layers. The single serial data stream also reduces cable
size, the number of connectors, and eliminates clock-to-data
and data-to-data skew.
评论(0)
发评论
下载排行榜
