IPC-TM-650 TEST METHODS MANUAL
消耗积分:10 | 格式:rar | 大小:444 | 2009-10-17
分享资料个
IPC-TM-650 TEST METHODS MANUAL:Time domain reflectometry, TDR, is used to measure reflections and time delays of pulses injected into a transmission line. Discontinuities in characteristic impedance, Z0, along the line under test, reflect portions of incident pulses back toward the source where they combine with the injected pulse to produce a voltage-time waveform.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
