SA58632 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-07-15
分享资料个
1. General description
The SA58632 is a two-channel audio amplifier in an HVQFN20 package. It provides
power output of 2.2 W per channel with an 8 Ω load at 9 V supply. The internal circuit is
comprised of two BTL (Bridge-Tied Load) amplifiers with a complementary PNP-NPN
output stage and standby/mute logic. The SA58632 is housed in a 20-pin HVQFN
package, which has an exposed die attach paddle enabling reduced thermal resistance
and increased power dissipation.
2. Features
n Low junction-to-ambient thermal resistance using exposed die attach paddle
n Gain can be fixed with external resistors from 6 dB to 30 dB
n Standby mode controlled by CMOS-compatible levels
n Low standby current < 10 µA
n No switch-on/switch-off plops
n High power supply ripple rejection: 50 dB minimum
n ElectroStatic Discharge (ESD) protection
n Output short circuit to ground protection
n Thermal shutdown protection
3. Applications
n Professional and amateur mobile radio
n Portable consumer products: toys and games
n Personal computer remote speakers
评论(0)
发评论
下载排行榜
