ADM869L,datasheet,pdf(Current
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-22
旧念
分享资料个
The ADM869L is a logic controlled P-channel switch with low
on resistance, capable of sourcing up to 2 A from supply voltages
between 2.7 V and 5.5 V. A user-settable current limit allows
the trip current to be set between 400 mA and 2 A with an
accuracy of ±21%. This allows the system power supply to be
protected against short circuits and surge currents in peripheral
loads powered via the ADM869L. Over-current and overtemperature
conditions are signalled by a FAULT output.
The ADM869L also offers low quiescent current of typically
12 μA and shutdown current of typically 10 nA.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
