ADR318,datasheet,pdf(Voltage R
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-23
h1654155957.9921
分享资料个
The ADR3181 is a precision 1.8 V band gap voltage reference featuring high accuracy, high stability, and low power consumption in a tiny footprint. Patented temperature drift curvature correction techniques minimize nonlinearity of the voltage change with temperature. The wide operating range and low power consumption with additional shutdown capability make the part ideal for battery-powered applications. The VOUT (SENSE) pin enables greater accuracy by supporting full Kelvin operation in PCBs employing thin or long traces.
The ADR318 is a low dropout voltage (LDV) device that provides a stable output voltage from supplies as low as 600 mV
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
