温度测量系统
图1中的电路显示了换能器的输出,如铂RTD桥,可数字化一个运算放大器。这个电路是一个修改,发现应用笔记43.1的LTC1292差动输入移除共模电压。使用的lt1006放大。电阻器之间的+输入的lt1006在LTC1292输入+补偿通过RS. Full桥的负载电阻规模可以通过500kΩ修剪盆栽调整和偏可以由100Ω修剪盆栽调整系列的比在这里使用AN43下rplat价值提高动态范围。在+上的信号电压不得超过VREF引脚。差分电压范围为VREF减去约100mV。这足够的范围测量0°C到400°C用0.1°C分辨率。
浮点,12位数据采集系统
图2中的电路演示了如何浮动LTC1292进行差分测量。该电路将数字化从10V至15V 12位5V范围分辨率。数字I / O已被翻译。这个lt1019-5用于分流模式创建浮动对于LTC1292模拟地。数字I/O线使使用4.3v齐纳管夹单晶体管逆变器。光电隔离器也可以使用。浮动模拟地面应为LTC1292地平面。这个47μF旁路电容应从VCC引脚绑具有最小导程和长度的浮动接地平面尽可能靠近设备放置。同样,保持从接地引脚到浮地的引线长度最低限度的平面(低轮廓插座是可以接受的)。
Differential Temperature Measurement System
The circuit in Figure 3 digitizes the difference in temperature between two locations. The two LM134s are used as temperature sensors. These are ideally suited for remote applications because they are current output devices. This allows long wires to run from the sensor back to the LTC1292 without any degradation to the signal from the sensor. Resistor RSET sets the current to 1μA/°K. The current is converted to a voltage by the resistor R1 connected from V– to ground. The reference voltage and resistor were selected to give a change of 0.05°C/LSB. The res olution is given by °C/LSB = VREF / ((4096) (1mA) (R1))。 The maximum temperature at each input is 125°C.
