Introduction
Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
This publication describes a variety of circuits featuring outputs from 200V to 1000V with output noise below 100µV measured in a 100MHz bandwidth. Special techniques enable this performance, most notably power stages optimized to minimize high frequency harmonic content. Although sophisticated, all examples presented utilize standard, commercially available magnetics—no custom components are required. This provision is intended to assist the user in quickly arriving at a produceable design. Circuits and their descriptions are presented beginning with the next ink.
Resonant Royer Based Converters The resonant Royer topology is well suited to low noise operation due to its sinosoidal power delivery1. Additionally, the resonant Royer is particularly attractive becausetransformers originally intended for LCD display backlight service are readily available. These transformers are multiply sourced, well proven and competitively priced. Figure 1’s resonant Royer topology achieves 100µVP-P noise at 250V output by minimizing high frequency harmonic in the power drive stage. The self oscillating resonant Royer circuitry is composed of Q2, Q3, C1, T1 and L1. Current flow through L1 causes the T1, Q2, Q3, C1 circuitry to oscillate in resonant fashion, supplying sinewave drive to T1’s primary with resultant sine-like high voltage appearing across the secondary.
图1.目前美联储罗耶谐振变换器产生高压输出。A1偏见Q1电流下沉,强制执行输出电压稳定反馈回路。A1的0.001µF–1kΩ网络相位超前输出滤波器,优化暂态响应。d5-d6,低漏夹,保护A1
