ADG1611/ADG1612/ADG1613,pdf da
消耗积分:5 | 格式:rar | 大小:556 | 2009-10-27
48674
分享资料个
The ADG1611/ADG1612/ADG1613 contain four independent single-pole/single-throw (SPST) switches. The ADG1611 and ADG1612 differ only in that the digital control logic is inverted. The ADG1611 switches are turned on with Logic 0 on the appropriate control input, while Logic 1 is required for the ADG1612 switches. The ADG1613 has two switches with digital control logic similar to that of the ADG1611; the logic is inverted on the other two switches. Each switch conducts equally well in both directions when on and has an input signal range that extends to the supplies. In the off condition, signal levels up to the supplies are blocked.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
