如何利用数字电源管理进行能量采集
数字电源管理是任何能源采集系统的重要组成部分。数字控制是允许一个单一的设备来处理范围广泛的能源有非常不同的要求,从光伏电池的最大功率点跟踪(MPPT)的压电和高阻抗的热源
该bq25505装置设计提取能量收集各种来源产生的微电。数字管理确保一个二次充电电池不收取多由这个提取的电源,电压升压,也不会耗尽超出安全限制的系统负载。
一个集成的多路复用器栅极驱动器自主切换系统负载到一个主要的非可充电电池,如果二次电池电压低于用户定义的阈值,允许设计人员为不同的应用程序优化系统。
Figure 1: The bq25505 from Texas Instruments showing the pins for the digital power management.
The design starts with a DC-DC boost charger that requires only microwatts of power to begin operating. The main boost charger is powered from the boost output, VSTOR, as shown in Figure 1. Once the VSTOR voltage is above the VSTOR_CHGEN generator value, typically 1.8 V, the boost charger can effectively extract power from low voltage output harvesters such as TEGs or single- or dual-cell solar panels that produce voltages down to 100 mV. When the boost output is less than 100 mV, the cold start circuit needs to have at least 330 mV to charge VSTOR up to 1.8 V.
