1. General description The SA58637 is a two-channel audio amplifier in an HVQFN20 package. It provides power output of 2.2 W per channel with an 8 Ω load at 9 V supply. The internal circuit is comprised of two Bridge-Tied Load (BTL) amplifiers with a complementary PNP-NPN output stage and standby/mute logic. The SA58637 is housed in a 20-pin HVQFN package, which has an exposed die attach paddle enabling reduced thermal resistance and increased power dissipation. 2. Features n Low junction-to-ambient thermal resistance using exposed die attach paddle n Gain can be fixed with external resistors from 6 dB to 30 dB n Standby mode controlled by CMOS-compatible levels n Low standby current < 10 µA n No switch-on/switch-off plops n High power supply ripple rejection: 50 dB minimum n ElectroStatic Discharge (ESD) protection n Output short circuit to ground protection n Thermal shutdown protection 3. Applications n Professional and amateur mobile radio n Portable consumer products: toys and games n Personal computer remote speakers
