The ADG658 and ADG659 are low voltage, CMOS analog multiplexers comprising eight single channels and four differential channels respectively. The ADG659 switches one of four differential inputs to a common differential output as determined by the 2-bit binary address lines A0, A1. An EN input on the device is used to enable or disable the device.
