ADG408/ADG409,pdf datasheet (L
消耗积分:10 | 格式:rar | 大小:225 | 2009-10-30
小峰
分享资料个
The ADG409 is a monolithic CMOS analog multiplexer comprising four differential channels. The ADG409 switches one of four differential inputs to a common differential output as determined by the 2-bit binary address lines A0 and A1. An EN input on the device is used to enable or disable the device. When disabled, all channels are switched OFF
评论(0)
发评论
下载排行榜
