The ADG529A is a CMOS monolithic analog multiplexer with dual 4 channels. On-chip latches facilitate microprocessor interfacing. The ADG529A switches one of 4 differential inputs to a common differential output depending on the state of two binary addresses and an enable input. It has TTL and 5 V CMOS logic compatible digital inputs
