// Chat.cpp : Defines the class behaviors for the application.
#include “stdafx.h”
#include “Chat.h”
#include “ChatDlg.h”
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CChatApp
BEGIN_MESSAGE_MAP(CChatApp, CWinApp)
//{{AFX_MSG_MAP(CChatApp)
// NOTE - the ClassWizard will add and remove mapping macros here.
// DO NOT EDIT what you see in these blocks of generated code!
//}}AFX_MSG
ON_COMMAND(ID_HELP, CWinApp::OnHelp)
END_MESSAGE_MAP()
// CChatApp construction
CChatApp::CChatApp()
// TODO: add construction code here,
// Place all significant initialization in InitInstance
// The one and only CChatApp object
CChatApp theApp;
// CChatApp initialization
BOOL CChatApp::InitInstance()
if(!AfxSocketInit())
AfxMessageBox(“加载套接字库失败!”);
return FALSE;
AfxEnableControlContainer();
// Standard initialization
// If you are not using these features and wish to reduce the size
// of your final executable, you should remove from the following
// the specific initialization routines you do not need.
#ifdef _AFXDLL
Enable3dControls(); // Call this when using MFC in a shared DLL
#else
Enable3dControlsStatic(); // Call this when linking to MFC statically
