在Popularity获得AC LED
当从主电源供电时,LED需要大而昂贵的驱动来将高交流电压转换成低直流电压。驱动程序增加的复杂性,成本和LED照明灯具的大小,推高固态照明(SSL)的价格和减缓主流采用。
“AC发光二极管”提供了另一种方法。尽管如此,这些发光二极管不是直接由高压交流电驱动的,而是使用各种方案来管理交流输入,这样单独的LED仅暴露于温和的电流和电压。然而,消除与传统设备使用的驱动程序已经看到AC LED开始从利基到主流应用程序迁移。
本文介绍了如何交流LED的发展,说明他们的优点和缺点,作为替代传统的SSL,并提出了一些商业解决方案的例子。
Not a drop-in replacement
LEDs, as the name indicates, are a form of diode. To operate, the devices demand a constant (relatively low) biasing (“forward”) voltage to ensure conduction and subsequent emission of photons resulting from recombinations of electrons and holes near the LED’s p-n junction.
Modern LEDs typically require a forward voltage (Vf) between 2.5 to 12 V resulting in a forward current (If) in the 350 mA to 5 A range, although many higher-voltage devices are available. For example, Lumileds’ LUXEON T requires a typical Vf of 2.8 V and can withstand a maximum current of 1.2 A. At a Vf of 2.8 V and If of 700 mA, luminosity is 218 lm and efficacy is 111 lm/W.
