Overview The STK682-010-E is a hybrid IC for use as a Bipolar, 2-phase stepping motor driver with PWM current control. Function Output on-resistance (High side 0.3 Ω, Low side 0.25 Ω, Total 0.55 Ω ; Ta = 25C, IO = 2.5A) VMmax=36V(DC), Iopmax=3.0A 2, 1-2, W1-2, 2W1-2, 4W1-2, 8W1-2, 16W1-2, 32W1-2 phase excitation are selectable With built-in automatic half current maintenance energizing function Over current protection circuit Thermal shutdown circuit Input pull down resistance With reset pin and enable pin
