UDA1334ATS pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-07-16
贾永世
分享资料个
The UDA1334ATS is a single chip 2 channel
digital-to-analog converter employing bitstream
conversion techniques, including an on-board PLL.
The extremely low power consumption and low voltage
requirements make the device eminently suitable for use
in low-voltage low-power portable digital audio equipment
which incorporates a playback function.
The UDA1334ATS supports the I
2S-bus data format with
word lengths of up to 24 bits and the LSB-justified serial
data format with word lengths of 16, 20 and 24 bits.
The UDA1334ATS has basic features such as
de-emphasis (44.1 kHz sampling frequency, only
supported in audio mode) and mute.
评论(0)
发评论
下载排行榜
