模拟有源音频滤波器
消耗积分:0 | 格式:pdf | 大小:443KB | 2017-05-20
汽车玩家
分享资料个
  Introduction
  Active audio filters may be used to compensate problems in frequency response of audio systems and loudspeakers. This paper deals with analog filters. These filters can produce a response that is approximately the inverse of a system response or a loudspeaker acoustic response so that when the two are summed the result is nearly flat. They may also be used to produce the difference of a target response minus the system or loudspeaker response, so that when the two are summed the result is nearly the target. In either case the final response is more accurate or more pleasing.
  Cell phone and PDA speaker responses like the one shown below often have annoying peaks that reduce intelligibility. This is compensated with the response of a biquad filter, also shown. The sum, the compensated response, is much more pleasing and far more intelligible than the original.
模拟有源音频滤波器
评论(1)
发评论
稻草人来了 2019-04-14
0 回复 举报
谢谢楼主分享 看看 收起回复
下载排行榜
全部1条评论
