能量收集技术延长电池寿命
消费者对移动电子产品的愿望进行了长期的电池寿命的默认期望,无论任何功能增强。能量收集技术可以帮助工程师大大延长原电池的寿命。对于设计师来说,建立电池扩展电路的任务已经从模拟设备,Cymbet,线性技术的专业集成电路的可用性变得相当方便,德克萨斯文书,其中。
能量收集提供了一种手段,使许多应用严格地从环境能源,包括太阳能,温差,振动或射频能量。对于这些“零功率”的设计,可用的环境能源超过设计功耗的要求-通常是因为应用程序带来了最小的功能要求很容易满足使用超低功耗元件。
For other applications, however, more complex application requirements can tip the power generation/consumption ratio away from zero-power solutions and instead dictate a need for one or more primary batteries. Even in these cases, designers can nevertheless find themselves facing a growing gap between power requirements and total-battery capacity. When the gap grows too large, consumers become dissatisfied with the product, perceiving it as too frequently requiring battery replacement or recharging.
