荧光体的发展解决了温白光LED的低功效
今天的照明标准的白色LED的使用InGaN半导体居多,发射光谱中蓝色部分的光,加上钇铝石榴石(YAG)荧光粉(掺铈)。大部分LED的蓝色光子被荧光粉吸收,并在光谱的黄色部分重新发射。剩余的蓝色光子和黄色照明的混合提供了一个很好的近似白光的眼睛。
这种LED和荧光粉的结合是一个成熟的技术,具有良好的性能,但它不是完美的。一个显着的不足是一个限制,高相关色温(CCT)和较低的显色指数(CRI)由于缺乏一个红色的组件在系统的输出。结合YAG荧光粉与其他材料增加红色的排放量,导致“温暖”白光LED的可用性,但在来之不易的成本成本。
本文详细介绍了这个问题,探讨如何制造商的LED照明的荧光体正在上升的挑战,然后认为他们的荧光体的研究将有什么影响的疗效,CCT和CRI的固态照明。
Blue LED plus YAG phosphor equals white light
The phosphor used for high-brightness LEDs is a highly specialized material comprising YAG doped with the rare-earth-element cerium (scientifically labeled as Y3Al5O12:Ce3+)。 The material was evolved from the phosphor used for CRTs and was first synthesized in 1967.
In operation, the LED’s blue photons are absorbed by atoms or molecules in the YAG phosphor, raising the constituent electrons to a higher energy level. The electrons then rapidly fall back to a lower level by re-emitting the energy partially as a photon of a longer wavelength (a little red, some green, and a lot of yellow) than the absorbed photon and partially as heat. (See the TechZone article “Whiter, Brighter LEDs.”)
