串联电压基准在功率受限的能量收集设计中提高精度
电压基准对于确保任何测量应用的准确性至关重要。对于能量采集驱动的传感器应用,工程师需要管理非常严格的功率预算,超低功耗电压基准提供所需的精度,同时消耗很少电流。工程师可以满足精密低功耗电压基准使用厂家包括模拟设备,Intersil,线性技术,集成,德克萨斯工具设备的需要,和试金石半导体。
在设计用来监视真实世界特性的应用程序中,精度取决于对已知电压基准执行测量的能力。一个稳定的参考电压传感器系统是必不可少的ADCs准确的数据转换,或能量存储的设计要求需要优化锂离子电池工作电压小心控制。设计师可以线性技术LTC6802锂离子电池监测与线性1461电压基准提供高度精确的李离子电池充电管理结合(图1)。
Figure 1: Voltage references provide high accuracy needed for applications such as those depending on accurate charge management needed for Li-ion energy storage (Courtesy of Linear Technology)。
Voltage references are designed to deliver a known output voltage with great precision and stability. Of course, any real device suffers variations from ideal due to manufacturing and environmental conditions. Manufacturer datasheets provide engineers with specifications for key device characteristics intended to convey output voltage error due to intrinsic and extrinsic factors.
