微ADC使能量收集无线传感器的设计
无线传感器系统采用了环境能量收集取决于最低功耗的模数转换器(ADC)可使用。对于这些系统,设计者通常不得不牺牲测量分辨率来实现低功耗需求。现在,然而,工程师可以找到一系列的低功耗、高精度的ADC厂商包括模拟设备,线性技术,瑞萨、德克萨斯文书,其中。
在多通道或单通道能量收集应用中,工程师需要在能量受限的设计中达到有限的功耗要求。因此,低功耗ADC在一个典型的能量收集无线传感器设计的信号链中发挥核心作用(图1)。
Figure 1: For a typical wireless sensor design, engineers require an analog-to-digital converter (ADC) with ultra-low-power requirements (Courtesy of Texas Instruments)。
For sensor applications, delta-sigma (ΔΣ) ADCs offer distinct performance advantages including high resolution and high noise immunity. In addition, today‘s leading ΔΣ devices typically provide output that is fully settled after a single conversion. This zero-latency conversion capability contrasts with earlier generations of ΔΣ ADCs, which required designers to build in a waiting period for additional conversions before retrieving data when the analog inputs changed.
