保护USB免受电源浪涌
The Universal Serial Bus (USB) has become the connection scheme of choice for interconnecting different devices, many of them providing human interface support. Support for many different types of peripheral, which can be self- or bus-powered, calls for stringent protection for not just the target device, but also the bus itself.
例如,USB供电设备的过电流保护是必要的,通过标准如UL60950,以及通过USB规范本身。还需要良好的静电放电(ESD)支持,以确保设备和主机不会受到设备插入引起的尖峰的不利影响,或者用户可以对USB连接器中暴露的引脚进行涂刷。本文着眼于要求保护的电源线和数据线USB和覆盖设备如TE电路保护polyswitch,意法半导体的usblc6,德克萨斯仪器tpdd4eusb30,NXP半导体ip4234cz6,Littelfuse 1206l家族和伯恩斯MF的家庭,其中。
USB外设的设计给工程师带来了一些挑战。其最新版本的USB规范允许非常高的数据速率,这就给系统设计带来了诸如信号完整性等方面的负担。同时,能够插入和拔出设备从一个活的系统–提供用户一个简单的方法来添加和删除的人机接口和其他设备–意味着背后的微妙的电子连接器需要保护电力突可以从销制造或主机系统的破坏接触。设计者还需要考虑由用户接触USB连接器或电缆的插头而引起的静电放电(ESD)效应。
To support high data rates and overall high performance, IC vendors have moved to semiconductor processes based on finer and finer geometries. The result of the shrink in process geometry is a decrease in ESD robustness, demanding that designers implement protection measures close to the connector.
