传感器阵列模拟开关和多路复用器
数据采集系统经常利用模拟开关和多路复用器将信号从现实世界的传感器和传感器子电路传输到我们的电路板上的电子信号调理和转换阶段。我们试着将电路板设置成尽可能有效地从频繁的边缘安装连接器获得信号到处理电路。然而,当我们在板的不同边缘上有几个传感器的多个连接器时,我们可以烧掉整个PCB层,只需模拟信号和模拟信号来保持噪音。
与此相关的是,我们也可能希望与传感器阵列共享电路。例如,我们可能想要监控和测量我们机器设计的几个位置的温度。这将需要许多温度传感器或热敏电阻分散设计。由于我们的微可转换只需要一个模拟信号到数字在任何一个时间,而不是重复的信号调理、缩放、偏移和增益阶段,它可能是更多的空间和成本效益的开关或多路多信号A/D,这个条件和路线,还可以节省I/O销有限的处理器,以及一个单一的点,不使用多个冗余的A/D线。
This article looks at analog switches and multiplexers that are readily available for engineers to use on boards when routing and passing analog signals to conditioning circuitry. All parts, datasheets, tutorials, and development kits mentioned are available online at Digi-Key’s website.
The basics
Analog switches, also called bilateral switches, typically use low ‘On Resistance” FETs in a matrix configuration to enable current to flow through a predefined path once the transistors are turned on into full saturation (Figure 1)。 You can look at an analog switch as behaving like a mechanical relay, except that instead of dry contacts, silicon junctions (PMOS and NMOS) electronically enable or disable conduction with no mechanical moving parts.
