实时软件过程之间的缓冲通信
消耗积分:0 | 格式:rar | 大小:0.11 MB | 2017-06-27
分享资料个
  实时软件过程之间的缓冲通信
  假设您有两个流程:服务器和客户机。服务器进程从硬件接口读取一些I/O,并将数据传递给客户机进程。这些进程可能在不同的处理器上运行,也可能不会运行。特别是,它们没有共同的共享内存区域。
  实时软件过程之间的缓冲通信
  In this situation the server and client have to communicate over some explicit pipe between them. This communication mechanism may be implemented in different ways depending on the system. The server part of this system can be run with code similar to the following pseudo-code:
  while (1) {
  get_data_from_pins();
  send_data_to_client();
  and the client part can run with the following code pattern:
  while (1) {
  wait_for_then_get_data_from_server();
  process_data();
  In this case, the server initializes the communication and the client waits for and responds to the communication. So the server is the master and the client is the slave. This is perhaps to be expected since the whole process is driven by the arrival of data on the hardware interface. So far, this is simple. However, things get a bit more complicated if timing requirements are taken into account. Depending on the needs of the system, the protocol between the two processes may have to be more complicated.
评论(0)
发评论
下载排行榜
