仔细看看能收获的Cymbet能量收集的开发工具
当生物电路开始进入我们的产品,我们将需要喂养它们。想象一下喂你的iPad。在此之前,我们的技术依赖于通过线路、电池和发电机提供的电能。
但正如T. Henry Morray所说,“世界是海中的能量,“能量收集工程师终于在密切关注能源我们周围,我们可以进军。而像Morray这样的人,和特斯拉追求和显示回避零点能量,辐射能量,真空能量,现代科学刚刚开始解开群众,能量收集工程师专注于更具体了解市售的来源如振动、光、热电、和电磁/射频。
本文以不同类型的能量采集源的能量分布看一看‘下罩在Cymbet能量收集评估套件。该套件接受太阳能,热,电磁/射频和振动源的能量。然后,它使能量充电给公司的固态充电电池,在我们的电路需要时,它又提供能量。
Baseline of understanding
The different harvested energy sources have very different characteristics. As a result, a good understanding of them will let us design better ways to capture their energy without waste.
Photovoltaic solar cells are the most common and most widely deployed energy harvesting devices. They come in a variety of sizes and power ratings and provide a variable DC power level proportional to the incident radiant intensity at wavelengths to which they are sensitive.
Overall, three main types of photovoltaic solar cells are available, based on monocrystalline, polycrystalline, and amorphous crystalline materials.
Monocrystalline and polycrystalline cells are the oldest types and are based on silicon semiconductors in crystalline form. They implement the photoelectric effect based on the separation of hole and electron pairs when exposed to light (see Figure 1).
