Low Power的16位单片机扩展8位和32位选项之间的应用空间
从一个角度看,16位MCU的适用性已成为有限公司,由有能力和低功耗的8位MCU的低端挤压,和32位MCU,迅速下降的价格在高端。事实上,一些MCU制造商的产品开发完全集中在8位和32位产品上。时间会告诉我们,如果这种策略是有缺陷的,因为最新的16位微控制器提供近在系统级功耗8位竞争比价,伴随着一个显着的性能优势。我们可以看到16位设备提供的应用程序段的扩展,特别是随着大多数电子系统对连接性的需求的增加。让我们来研究一下与8位和32位竞争相对应的最新16位技术的发展情况。
首先,我们应该解决影响8位、16位或32位设备选择的一般因素。在低端,这个决定通常是为了降低成本和低功耗。一般来说,8位设备在这些领域胜出。但是,正如我们将在这里,有16点可以在功耗和成本方面有8位MCUs竞争。
There are certainly other factors that can come into play. For example, we covered the 8-bit 6- and 8-pin MCU segment in a TechZone article last year (Miniature Six-Pin MCUs Offer Surprising Functionality)。 If minimal footprint on your printed circuit board is a prime decision factor, you may not find 16-bit devices that can match the smallest 8-bit devices.
Decisions between 16- and 32-bit MCUs most often come down to the combination of performance and peripherals that can handle the task at hand balanced against power consumption and cost. Microchip product marketing manager Alexis Alcott said, “It‘s a lot less about bits, and more about the other requirements.”
