C8051F042
25 MIPS, 64 kB Flash, 10-Bit ADC, 100-Pin Mixed-Signal MCU
Analog Peripherals
10-Bit ADC
-±1 LSB INL; guaranteed monotonic
-Programmable throughput up to 100 ksps
-13 external inputs; programmable as single-ended or differential
-Programmable amplifier gain: 16, 8, 4, 2, 1, 0.5
-Data-dependent windowed interrupt generator
-Built-in temperature sensor (±3 °C)
High-Voltage Differential Amplifier
-60 V common mode input range
-Offset adjust from –60 to +60 V
-16 gain settings from 0.05 to 16
8-Bit ADC
-Programmable throughput up to 500 ksps
-8 external inputs; programmable as single-ended or differential
-Programmable amplifier gain: 4, 2, 1, 0.5
Two 12-Bit DACs
Three Comparators
Internal Voltage Reference
Precision VDD Monitor/Brown-out Detector
On-Chip JTAG Debug & Boundary Scan
-On-chip debug circuitry facilitates full speed, non-intrusive in-system debug (no emulator required)
-Provides breakpoints, single stepping, watchpoints, stack monitor, program
trace memory
-Inspect/modify memory and registers
-Superior performance to emulation systems using ICE-chips, target pods, and sockets
-IEEE1149.1 compliant boundary scan
Supply Voltage: 2.7 to 3.6 V
-Typical operating current: 10 mA at 25 MHz
-Multiple power saving sleep and shutdown mode
Temperature Range: –40 to +85 °C
