C8051F043 pdf datasheet
消耗积分:2 | 格式:rar | 大小:555 | 2008-07-19
哈哈哈
分享资料个
ANALOG PERIPHERALS
10-bit ADC
- ±1LSB INL; Guaranteed Monotonic
- Programmable Throughput up to 100ksps
- 12 External Inputs; Programmable as Single-Ended or Differential
- Programmable Amplifier Gain: 16, 8, 4, 2, 1, 0.5
- Data Dependent Windowed Interrupt Generator
- Built-in Temperature Sensor (± 3°C)
High-Voltage Differential Amplifier
- 60V Common Mode Input Range
- Offset Adjust from –60V to +60V
- 16 Gain Settings from 0.05 to 16
8-bit ADC
- Programmable Throughput up to 500ksps
- 8 External Inputs; Programmable as Single-Ended or Differential
- Programmable Amplifier Gain: 4, 2, 1, 0.5
Two 12-bit DACs
Three Comparators
Internal Voltage Reference
Precision VDD Monitor/Brown-out Detector
ON-CHIP JTAG DEBUG & BOUNDRY SCAN
- On-Chip Debug Circuitry Facilitates Full Speed, Non-Intrusive In-
System Debug (No Emulator Required!)
- Provides Breakpoints, Single Stepping, Watchpoints, Stack
Monitor, Program Trace Memory
- Inspect/Modify Memory and Registers
- Superior Performance to Emulation Systems Using ICE-Chips,
Target Pods, and Sockets
- IEEE1149.1 Compliant Boundary Scan
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
