如何扩展2.45 GHz无线系统的范围
广泛使用的2.45 GHz短距离无线电系统,如蓝牙低能耗和ZigBee是成熟的技术,特别适用于物联网(物联网)应用。虽然这个频段的收音机确实有很好的穿墙和测距性能,但在智能照明中,有些节点离发射枢纽很远,迫使系统设计者考虑其范围扩展选项。
提高这些系统范围的解决方案包括网状网络,即将信号从一个节点传输到下一个节点,或者诸如蓝牙5的纠错算法等技术,这限制了比特误码率(BER)。然而,网状网络增加了复杂性,而蓝牙5的范围扩展是以降低数据速率为代价的。看,“蓝牙4.1,4.2和5兼容的蓝牙低功耗SoC和工具满足物联网的挑战(1)。”
增加范围的另一种解决方案是提高电台的“链路预算”与低噪声放大器(LNA)和功率放大器(PAs)与射频芯片。通过选择射频前端模块(FEM),在预组装和测试的封装中包括低噪声放大器、低噪声放大器、射频开关和逻辑电路,可以简化放大设计。
There are some drawbacks to this solution, however, including increased cost and size, and greater power consumption. The designer must also consider U.S. FCC and other international regulations regarding transmission power in the unlicensed RF bands.
This article describes how RF FEMs increase the range of short range radio systems for IoT applications, discusses the drawbacks compared with alternatives, and provides application examples to illustrate the design process.
