集成点负载功率模块提供了一个完整的解决方案,具有可伸缩性
今天,分布式电源架构已经演变成中间总线架构(IBA),它提供了所需的电压驱动多种DC直流用于数据通信/电信设备系统板转换器、服务器和个人电脑。这些直流/直流转换器作为负载点(POL)电压调节器和提供所需的降压电力负荷变化如微处理器,DSPs回忆,这些板发现逻辑和其他设备
设计离散元件的电压调节器繁琐,费时,效率低,占用更多的空间。让生活更容易为设计者和给他们的其他系统需要更多的时间,生产厂家如Intersil,国际整流器、德克萨斯仪器等,已经开发出高度集成的POL模块,提供完整的直流/直流转换器的解决方案,可扩展性,以满足广泛的POL电源要求。因此,升级到下一级的电力需求意味着只需选择一个引脚的引脚兼容,更高的性能的集成的家庭,不改变电路板。
采取,例如,Intersil的isl820xm系列,这是一个高度集成的20 V输入和负载点(POL)的可变输出降压直流/直流转换器家族成员引脚引脚兼容。综合isl820xm模块包括一个高性能PWM控制器,功率MOSFET,电感,和大多数要求完成直流/直流电源的无源元件。所有这些组件都装在一个15×15毫米QFN封装。在600 kHz的开关,isl820xm的输出电流能力从4到10,而isl8201m是一个20 V,10输出电流模型,该isl8204m和isl8206m 4和6引脚兼容的版本,分别。
The pin-compatible common footprint makes it easy for a designer to migrate from one module to another without changing the PC-board layout. Hence, when a design has to scale from lower current to higher output current, a designer can simply remove the old part and replace it with a higher-current member, without any circuit changes, to reduce time to market.
Thus, one simple layout fits all members of this module family. However, to create a complete high-current solution on the board at the POL, it requires bulk input and output capacitors and one resistor to program the output voltage from 0.6 to 6.0 V (Figure 1)。 Using voltage-mode control, the output voltage can be precisely regulated to as low as 0.6 V with up to ±1 percent output voltage regulation. The ISL8201M also features internal compensation, internal soft-start, auto-recovery overcurrent protection, an enable option, and pre-biased output.
