具有省电功能的先进无刷直流电机控制器
如何在保持小碳足迹的同时节约能源是世界各国关注的热点。现在全球正在努力控制环境污染和防止严重的气候波动。各国还试图就如何最好地保护地球有限的能源资源达成协议。对大多数人来说,节约能源意味着在不需要的时候关掉电源,而不是开车、能源回收等等。然而,除了这些生活方式的调整之外,还有一个不那么明显的能源效率问题。
据美国电力研究院(EPRI)的研究,汽车占世界能源消费总量的51%,在950亿美元的年度成本。其他部门消耗的能源相对较低。例如,照明占19%,制冷和取暖16%,14%。
事实上,无论使用哪种方式,无论是家用的还是商用的,电动机都消耗了最多的能量。例如,在2007,台湾的总电力消费为1172亿千瓦时。在1172亿千瓦时的电力中,电动机消耗820亿千瓦时,占总用电量的70%。如果电动机的能源效率可以提高,就可以节省大量能源。
这就解释了为什么所有国家都在积极制定提高电机和照明产品功率效率的计划。
Household appliances basically consume power for two purposes: converting electric power into other forms of energy output (lighting, TV), and powering motors (refrigerators, washing machines, air conditioners, fans, vacuum cleaners)。 Powering motors usually accounts for 70 percent of the total electricity a household consumes. According to research done by the Taiwan Engineering Research Institute, if motors in Taiwan had an improved energy efficiency of 10 percent, there would be an annual energy saving of 10 billion KWH. This would be equivalent to the power generated by a large-scale nuclear facility. If the total annual global production of energy amounts to 20.2 mega KWH, such an improvement would result in energy savings of a whopping 2 mega KWH. This is equivalent to the power generated by 200 large-scale nuclear facilities.
