Description The BPP1N5004D(S) is a high voltage 1-Phase IPM (Intelligent Power Module)。 It integrate HVIC and high-performance MOSFET for BLDC and PMSM motors. Separate Open-Source Pins from Low-Side MOSFETs for Current-Sensing. The input is work with Schmitt-trigger and the logic voltage level is compatible with 3.3V/5V/15V signal. UVLO, dead time and thermal monitoring is also provide.
Features Built-in high-performance 500V/4A MOSFET Robust at negative transient voltage Gate drive supply range from 10V to 20V 3.3V, 5V and 15V input logic input compatible UVLO for both high side and low side Built-in dead time to avoid cross-conduction Available in DIP8 and SOP8 package
