Diodes Incorporated 集成电路(IC) PAM3103AABADJ
消耗积分:0 | 格式:rar | 大小:0.49 MB | 2017-08-30
分享资料个
  The PAM3103 is a positive, adjustable linear regulator. It features low quiescent current (65µA typ.) and low dropout voltage, making it ideal for battery powered applications. The output voltage is adjustable from 1.2V through 5V. Its high PSRR makes it useful in applications that require AC noise suppression on the input power supply. Spacesaving SOT23-5 and SOT353(SC70-5) packages are attractive for portable and handheld applications. It has both thermal shutdown and a current limit features to prevent device failure under extreme operating conditions. It is stable with an output capacitor of 2.2µF or greater.
评论(0)
发评论
下载排行榜
