Diodes Incorporated 集成电路(IC) AP2111H-3.3TRG1
消耗积分:0 | 格式:rar | 大小:0.79 MB | 2017-08-30
分享资料个
  The AP2111 is CMOS process low dropout linear regulator with enable function, the regulator delivers a guaranteed 600mA (Min) continuous load current. The AP2111 provides 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 4.8V regulated output and 0.8V to 5V adjustable output, and provides excellent output accuracy 1.5%, it is also provides a excellent load regulation, line regulation and excellent load transient performance due to very fast loop response. The AP2111 has built-in auto discharge function. The AP2111 features low power consumption. The AP2111 is available in SOIC-8, PSOP-8 SOT-223 and SOT-23-5 packages.
  Output Voltage Accuracy: ±1.5% • Output Current: 600mA (Min) • Foldback Short Current Protection: 50mA • Enable Function to Turn On/Off VOUT • Low Dropout Voltage (3.3V): 250mV (Typ) @ IOUT=600mA • Excellent Load Regulation: 0.2%/A (Typ) • Excellent Line Regulation: 0.02%/V (Typ) • Low Quiescent Current: 55μA (Typ) • Low Standby Current: 0.01μA (Typ) • Low Output Noise: 50μVRMS • PSRR: 65dB @ f=1kHz, 65dB @ f=100Hz • OTSD Protection • Stable with 1.0μF Flexible Cap: Ceramic, Tantalum and Aluminum Electrolytic • Operating Temperature Range: -40°C to 85°C • ESD: MM 400V, HBM 4000V
评论(0)
发评论
下载排行榜
