三星贴片电容规格参数
消耗积分:1 | 格式:pdf | 大小:7449KB | 2017-08-31
胡工
分享资料个
三星贴片电容规格参数
  We, Samsung, declare that our component MLCC is produced in accordance with EU RoHS directive. 1.RoHS Compliance and restriction of Br The following restricted materials are not used in packaging materials as well as products in compliance with the law and restriction. - Cd, Pb, Hg, Cr+6, As, Br and the compounds, PCB, asbestos - Bromic materials : PBBs, PBBOs, PBDO, PBDE, PBB 2.No use of materials breaking Ozone layer The following ODS materials are not used in our fabrication process. - ODS material : Freon, Haron, 1-1-1 TCE, CCl4, HCFC
  •Wide selection of size : from 0402 to 2220 •Highly reliable tolerance and high speed automatic chip placement on PCBs •Wide capacitance range •Wide temperature compensation and voltage range : from C0G to Y5V and from 6.3V to 50V •Highly reliable performance •Highly resistant termination metal •Tape & reel for surface mount assembly
三星贴片电容规格参数
评论(0)
发评论
下载排行榜
