具有低待机模式的1.2 W音频功率放大器TS4990
消耗积分:0 | 格式:rar | 大小:0.73 MB | 2017-09-01
分享资料个
  Description The TS4990 is designed for demanding audio applications such as mobile phones to reduce the number of external components. This audio power amplifier is capable of delivering 1.2 W of continuous RMS output power into an 8 Ω load at 5 V. An externally controlled standby mode reduces the supply current to less than 10 nA. It also includes an internal thermal shutdown protection. The unity-gain stable amplifier can be configured by external gain setting resistors.
  Features ■ Operating range from VCC = 2.2 V to 5.5 V ■ 1.2 W output power at VCC = 5 V, THD = 1%, F = 1 kHz, with 8 Ω load ■ Ultra-low consumption in standby mode (10 nA) ■ 62 dB PSRR at 217 Hz in grounded mode ■ Near-zero pop and click ■ Ultra-low distortion (0.1%) ■ Unity gain stable ■ Available in 9-bump flip-chip, miniSO-8 and DFN8 packages
评论(0)
发评论
下载排行榜
