2A,1.2伏摆率控制负荷开关SiP32411
消耗积分:0 | 格式:rar | 大小:0.43 MB | 2017-09-11
分享资料个
  DESCRIPTION The SiP32411 is a slew rate controlled load switch that is designed for 1.1 V to 5.5 V operation. The device guarantees low switch on-resistance at 1.2 V input. It features a controlled soft-on slew rate of typical 150 μs that limits the inrush current for designs of capacitive load or noise sensitive loads. The device features a low voltage control logic interface (on/off interface) that can interface with low voltage digital control without extra level shifting circuit. It also integrates an output discharge switch that enables fast shutdown load discharge. When the switch is off, it provides the reverse blocking to prevent high current flowing into the power source. The SiP32411DN is in TDFN4 package of 1.2 mm by 1.6 mm. It supports over 2 A of continuous current. The SiP32411DR is in SC70-6 package.
评论(0)
发评论
下载排行榜
