lytswitch大功率LED驱动IC系列LYT4317E
消耗积分:0 | 格式:rar | 大小:2.30 MB | 2017-09-12
分享资料个
  High Performance, Combined Driver, Controller, Switch The LYTSwitch family enables off-line LED drivers with high power factor which easily meet international requirements for THD and harmonics. Output current is tightly regulated with better than ±5% CC tolerance1 。 Efficiency of up to 92% is easily achieved in typical applications. Supports a Wide Selection of TRIAC Dimmers The LYTSwitch family provides excellent turn-on characteristics for leading-edge and trailing-edge TRIAC dimming applications. This results in drivers with a wide dimming range and fast start-up, even when turning-on from a low conduction angle. Large dimming ratio and low “pop-on” current. Low Solution Cost and Long Lifetime LYTSwitch ICs are highly integrated and employ a primary-side control technique that eliminates the optoisolator and reduces component count. This allows the use of low-cost single-sided printed circuit boards. Combining PFC and CC functions into a single-stage also helps reduce cost and increase efficiency. The 132 kHz switching frequency permits the use of small, low-cost magnetics. LED drivers using the LYTSwitch family do not use primary-side aluminum electrolytic bulk capacitors. This means greatly extended driver lifetime, especially in bulb and other high temperature applications.
评论(0)
发评论
下载排行榜
