AVR910 In-System Programming
消耗积分:0 | 格式:rar | 大小:0.15 MB | 2017-09-21
分享资料个
  To assure proper communication on the three SPI lines, it
  is necessary to connect ground on the programmer to
  ground on the target (GND)。
  To enter and stay in Serial programming mode, the AVR
  microcontroller reset line has to be kept active (low)。 Also,
  to perform a Chip Erase, the Reset has to be pulsed to end
  the Chip Erase cycle. To ease the programming task, it is
  preferred to let the programmer take control of the target
  microcontroller reset line to automate this process using a
  fourth control line (Reset)。
  To allow programming of targets running at any allowed
  voltage (2.7V - 6.0V), the programmer can draw power
  from the target system (VCC)。 This eliminate the need for a
  separate power supply for the programmer. Alternatively,
  the target system can be supplied from the programmer at
  programming time, eliminating the need to power the target
  system through its regular power connector for the duration
  of the programming cycle.
  Figure 2 shows the connector used by this In-System programmer to connect to the target system. The standard
  connector supplied is a 2 x 3 pin header contact, with pin
  spacing of 100 mils.
评论(0)
发评论
下载排行榜
