Simplified Approach for Predic
消耗积分:3 | 格式:rar | 大小:344 | 2009-11-29
分享资料个
Simplified Approach for Predicting Dynamic Thermal Behavior of Switching Electronic Devices:Abstract: Thermal investigation is a fundamental issue in power converter design since IGBT’s (Insulate Gate Bipolar Transistor) are widely used in the application of motor drivers, switching supplies and other power conversion systems. Accurate thermal prediction of junction temperature of semiconductor devices has become the major issue with the increase of the current density and high switching frequency of advanced power devices. The paper presents a simplified approach for predicting working temperature of switching devices. As an example IGBT PWM (Pulse-Width Modulation) inverter is given to demonstrate the application of this approach. Based on the measurement of IGBT's dynamic characteristics, the estimation of power loss considering the junction temperature is introduced. Then the finite element analysis is used to accurate peak junction temperature prediction needed during dynamic operating conditions. In addition, the effect of switching frequencies during transient thermal response is investigated. The new approach developed can be used for accurate rating semiconductor devices or heat sink systems in power circuit design. Results comparison between proposed approach and commercial simulator shows that this approach is effective as a designing step.
评论(0)
发评论
下载排行榜
