德信6862风扇的IC资料
消耗积分:1 | 格式:pdf | 大小:575KB | 2017-10-18
小小尹
分享资料个
德信6862风扇的IC资料
  EUM6862/A/B is a fan motor driver for the single coil brushless DC motor. With its high efficient direct PWM control mode, EUM6862/A/B controls the speed of brushless DC motor with a built in HALL IC interface. EUM6862/A/B is suitable to drive variable speed motors for personal computer’s power supply radiation fans and CPU coolers. EUM6862/A/B integrates PWM fan speed control, minimum speed mode, soft start, fan tachometer, lock protection, auto restart and Hall Bias functions. PWM mode controls fan speed in low noise and low vibration ways by adjusting RCTL voltage. EUM6862/A/B can set minimum fan speed by presetting RMIN voltage. With soft start function, EUM6862/A/B can drive motor from slow speed to fast speed in a settable time by setting the external capacitor between SS and GND. If a fan motor is stalled by the external force or obstacles, overdrive current may incur coil overheat and burning. To prevent motor from overheating, the lock protection circuit shuts down the internal power devices for a few seconds after the motor lock is detected. Then the auto restart circuit resumes to power up the internal power devices. If the lock persists, EUM6862/A/B shuts off power devices for a few seconds. The lock protection delay time is externally programmable by a capacitor. EUM6862 has built in motor rotation speed feedback (FG) output, motor rotation detection (RD) output and Hall sensor bias output.
德信6862IC资料
评论(0)
发评论
下载排行榜
