JX-H65随着960p MIPI接口的CMOS图像传感器
消耗积分:2 | 格式:pdf | 大小:3722KB | 2017-10-30
吴志乾
分享资料个
JX 720P CMOS SENSOR Datasheet
  JX-H65 is an HD CMOS image sensor designed and fabricated with SOI’s 3.75um pixel technology 。 It can deliver images at 60fps in 960P mode and 30fps in HDR mode. The JX-H65 consists of a 1292 x 968 active pixel sensor (APS) array with on-chip 10-bit ADC, programmable gain control (PGA), and correlated double sampling (CDS) to significantly reduce fixed pattern noise (FPN)。 The sensor also has many standard programmable and automatic functions. It has both the industry compliant DVP parallel and MIPI CSI2 dual-data lane serial interfaces. The external host controller can access this device through a standard serial interface. It is available in wafer-level packaged CSP.
评论(2)
发评论
tuzi2237 2017-12-04
0 回复 举报
谢谢分享很有用 收起回复
tuzi2237 2017-12-02
0 回复 举报
谢谢分享 收起回复
下载排行榜
全部2条评论
