陶瓷天线Nodic nRF51822 蓝牙4.2模块SKB36
消耗积分:0 | 格式:pdf | 大小:0.33 MB | 2017-11-15
skylab01
6年用户
分享资料170个
陶瓷天线,Nodic nRF51822 蓝牙4.2模块SKB361
  陶瓷天线,Nodic nRF51822 蓝牙 4.2 模块 SKB361
  SKYLAB(Ella)
  一、产品简介
  SKB361 是一款高集成的蓝牙 4.2BLE 模块,专为在 2.4G ISM 皮带的短程无线高速率传输
  设计!模块是基于 Nordic nRF51822 无线收发芯片制作,有 32 bit ARM Cortex-M0 CPU,闪存
  和模拟数字外设,为无线传输应用提供低功耗,低成本的 BLE 解决方案!
  二、产品图片
  陶瓷天线,Nodic nRF51822
  尺寸:17.4*13.7*1.9(mm)
  1
  定位现在,连接未来
  三、产品参数:
  l Main Chip: nRF51822
  l Bluetooth® 4.2 compliant low energy single-mode protocol stack L2CAP, ATT, and SM protocols
  GATT, GAP, and L2CAP Peripheral and Broadcaster roles GATT Client and Server
  Full SMP support including MITM and OOB pairing l 2.4 GHz transceiver
  -93dBm sensitivity in Bluetooth low energy mode 250Kbps, 1Mbps, 2Mbps supported data rates
  Tx Power -20 to +4 dBm in 4 dB steps Tx Power -30 dBm Whisper mode 13mA peak RX, 10.5mA peak Tx (0dBm) RSSI (1 dB resolution)
  l Flexible Power Management Supply voltage range 1.8V to 3.6V 2.5us wake-up using 16MHz RCOSC 0.6uA@3V OFF mode
  1.2uA@3V in OFF mode +1 region RAM retention 2.6uA@3V ON mode, all blocks IDLE
  2
  定位现在,连接未来
  l 8/9/10 bit ADC-6 configurable channels l 20 General Purpose I/O pins
  l SPI Master/Slave
  l Two-wire Master (I2C compatible) l UART (CTS/RTS)
  l CPU independent Programmable Peripheral Interconnect (PPI) l Quadrature Decoder (QDEC)
  l AES HW encryption
  l Dimension: 17.4x13.7 mm
评论(0)
发评论
下载排行榜
