AT89C51
消耗积分:10 | 格式:rar | 大小:544 | 2009-12-13
张静
分享资料个
The AT89C51 is a low-power, high-performance CMOS 8-bit microcomputer with 4K
bytes of Flash Programmable and Erasable Read Only Memory (PEROM). The
device is manufactured using Atmel’s high density nonvolatile memory technology
and is compatible with the industry standard MCS-51™ instruction set and pinout. The
on-chip Flash allows the program memory to be reprogrammed in-system or by a conventional
nonvolatile memory programmer. By combining a versatile 8-bit CPU with
Flash on a monolithic chip, the Atmel AT89C51 is a powerful microcomputer which
provides a highly flexible and cost effective solution to many embedded control applications.
评论(2)
发评论
2011-09-30
0 回复 举报
英文版的,喜欢 收起回复
ggp001 2011-04-22
0 回复 举报
不会是英文版吧 收起回复
下载排行榜
全部2条评论
