Features
For surface mounted application Easy pick and place
Metal to silicon rectifier, majority carrier conduction Low power loss, high efficiency
High current capability, low VF High surge current capability
Plastic material used carriers Underwriters Laboratory Classification 94V-0
Epitaxial construction
High temperature soldering: 260oC / 10 seconds at terminals
Mechanical Data
Case: JEDEC SMA/DO-214AC Molded plasticDimensions in inches and (millimeters)
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Packaging: 12mm tape per EIA STD RS-481
Weight: 0.066 gram
Maximum Ratings and Electrical Characteristics
Rating at 25oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
