TC1306 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-08-05
张艳
分享资料个
The TC1306 combines two CMOS Low Dropout Regulators
and a Microprocessor Monitor in a space saving
8-Pin MSOP package. Designed specifically for battery
operated systems, total supply current is typically
120μA at full load, 20 to 60 times lower than in bipolar
regulators.
The TC1306 features selectable output voltages for
higher design flexibility. The dual-state SELECT input
pin allows the user to select VOUT2 from 2 different
values (2.8V and 3.0V). VOUT1 supplies a fixed 1.8V
voltage.
An active low RESET is asserted when the output
voltage VOUT2 falls below the 2.63V reset voltage
threshold. The RESET output remains low for 300msec
(typical) after VOUT2 rises above reset threshold. When
the shutdown control (SHDN1) is low, the regulator
output voltage VOUT1 falls to zero and RESET output
remains valid. When the shutdown control (SHDN2) is
low, the regulator output voltage VOUT2 falls to zero and
RESET output is low.
Other key features for the device include ultra low noise
operation, fast response to step changes in load and
very low dropout voltage (typically 125mV at full load).
The device also incorporates both over temperature
and over current protection. Each regulator is stable
with an output capacitor of only 1μF and has a
maximum output current of 150mA.
评论(0)
发评论
下载排行榜
